KZ750E1 - FIGHTER Build
  • 650mod
  • 650mod's Avatar
Re: KZ750E1 - FIGHTER Build
25 Apr 2013 13:02
#583968
Mike,
Are you going to end up putting a slight kick-up in the exhaust then as it's dragging? How does it handle/ride otherwise?
Devin
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
25 Apr 2013 16:33
#583994
mike0537 wrote:
531blackbanshee wrote: looks like you could use a rub strip on the front of that arm under the chain run.
I've got one on there! ;)
is that the area where the chain is slapping?
  • mike0537
  • mike0537's Avatar Topic Author
26 Apr 2013 02:13
#584052
650mod wrote: Mike,
Devin
I haven't decided exactly what to do with the exhaust yet. From the 8-10 miles so far under 45mph, it is great!!
1980 KZ750E
  • mike0537
26 Apr 2013 02:14
#584053
The noise went away. Chain was a little tight to begin with and now it is super loose. Do new non o-ring chains stretch that fast?
1980 KZ750E
  • mike0537
26 Apr 2013 02:26
#584055
Just a view I like. Still working on side covers though...
[IMG
1980 KZ750E
  • donthaveakawman
  • donthaveakawman's Avatar
26 Apr 2013 03:10
#584061
B) ;) :) :P :laugh: :ohmy: :angry: :blink: :( :unsure: :kiss: :woohoo: :woohoo: :lol: :silly: :pinch: :side: :whistle: :evil: :woohoo: :woohoo: :S :blush: :cheer: :huh: :huh: :dry: B) ;)
standing ovation, the crowd goes wild. nice job.
26 Apr 2013 09:51 - 26 Apr 2013 09:52
#584075
mike0537 wrote: ..... Chain was a little tight to begin with and now it is super loose. Do new non o-ring chains stretch that fast?
No, they barely stretch at all in many thousands of miles. I have had my D.I.D. o-ring chain on my bike for 18,000 miles and have only adjusted it about 1/8". I ride pretty hard (but I don't do wheelies) so I don't think the riding style has too much of an impact on chain stretch unless the bike is used on the track. I do lube the chain using Maxima Chain Wax every 3-500 miles.
I believe you identified the problem when you said "Chain was a little tight to begin with." The drive chain MUST have some slack in it when installed and adjusted. You should be able to move the center of the bottom run of chain up and down 20 - 30mm. The thing to keep in mind is that as you ride and the swing arm pivots up and down the distance between the center of the front sprocket and rear sprocket changes. This is because the center of the swing arm pivot and center of front sprocket are not concentric. So when you sit on the bike and go over a bump, and the swing arm moves up relative to the frame, the chain gets tighter. That's why if the chain starts out rather tight when the bike is just sitting at rest it will be forced to stretch when the bike is ridden, so that 20-30mm of slack is important. The other factor is the sprockets. New sprockets need to be installed with the new chain. The sprockets and chain wear as a set as the bike is ridden. So even though the old sprockets may not look too bad, the dimensions of the teeth have worn and won't correctly match the dimensions of the chain. This will cause premature chain wear. Also, if new sprockets are put on with an old chain the chain will wear out the new sprockets prematurely. Ed
Last edit: 26 Apr 2013 09:52 by 650ed.
  • kzz1king
  • kzz1king's Avatar
26 Apr 2013 11:45
#584093
To add what Ed said when doing a custom rear end I think you should find the longest point of the arm (when level with pivot usually) and have a tad slack there. Like mentioned above if it is to tight when the arm moves it will stretch it. A tight chain is a fast way to ruination!
Wayne
Home built KZ1000 turbo setup
  • tucsonKZ1kP
  • tucsonKZ1kP's Avatar
26 Apr 2013 12:02
#584097
I believe you were the dude who commented on my build i just posted... Somehow it got into the engine forum. weird, but now its in the project bike section and I am going through your build. check mine out when you get a chance because i think you can help me answer some questions. Awesome bike so far...
  • homert1
  • homert1's Avatar
26 Apr 2013 12:18
#584102
could you send in some more pics?? Nice job! I'm looking to do something similar and need some more ideas before I start tearing things apart
  • mike0537
26 Apr 2013 16:22
#584140
homert1 wrote: could you send in some more pics?? Nice job! I'm looking to do something similar and need some more ideas before I start tearing things apart
What would you like more pictures of?
1980 KZ750E
  • mike0537
26 Apr 2013 19:57
#584164
tucsonKZ1kP wrote: I believe you were the dude who commented on my build i just posted... Somehow it got into the engine forum. weird, but now its in the project bike section and I am going through your build. check mine out when you get a chance because i think you can help me answer some questions. Awesome bike so far...
I have looked. Ask whatever questions you like. There are a lot of members that will also be able to help.
1980 KZ750E
