KZ/GPZ mono shock hack was Budget Turbo Build
  • kzz1king
  • kzz1king's Avatar Topic Author
28 Jun 2012 22:28 - 12 Jan 2013 13:58
#532476
About 7 years ago I decided I needed to turbo charge something. I spent much time searching different forums and trading communication in attempt to build, so caled, cheap horsepower. I got the bike to build boost for a bit but no longer. I plan to go all through it this winter and try and get it figured out.
Attachment DSCN1154.JPG not found
Attachment DSCN1156.JPG not found
Home built KZ1000 turbo setup
Last edit: 12 Jan 2013 13:58 by kzz1king. Reason: Changed direction of thread
  • kzz1king
Re: KZ mono shock was Budget Turbo Build
28 Jun 2012 22:32 - 11 Jan 2013 23:33
#532479
I used an old exhaust and mandrel bens for the header,
Attachment DSCN1157.JPG not found
Attachment DSCN1158.JPG not found
Last edit: 11 Jan 2013 23:33 by kzz1king.
  • kzz1king
Re: Budget Turbo Build
28 Jun 2012 22:36
#532481
Turbo is a Garret T25 from a Mitsi Eclipse. Had to cut and turn the output. Also added seals for draw through use. It is oiled by a shurflo pump under the modded tailpiece. Uses the stock wastegate.
Attachment DSCN1159.JPG not found
Attachment DSCN1162.JPG not found
Attachment DSCN1161.JPG not found
Attachment DSCN1164.JPG not found
  • ramtough_63
  • ramtough_63's Avatar
28 Jun 2012 22:39
#532483
cool looking forward to this
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • kzz1king
28 Jun 2012 22:40
#532484
Homemade oil tank for turbo. I also use a pressure switch that will not allow power to coils if pump is not on or fails. Use a cheap electric pump to feed the mikuni. It starts and runs well but does not make boost. I am thinking a possible exhaust or intake leak.
Attachment DSCN1163.JPG not found
  • jeffasaki
  • jeffasaki's Avatar
28 Jun 2012 23:06
#532491
you may wanna check out 750turbo.com
lots of good info there
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • gearheadmm
  • gearheadmm's Avatar
  • MUCH MORE BOOST..........I mean BRAVO
28 Jun 2012 23:43
#532504
Cool intake, Big volume! Check your wastegate, I've seen those valves fall out and then will run good but not make boost. Remove turbine outlet pipe and see if its still there.
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
29 Jun 2012 11:26
#532601
really cool project you got here,
  • les holt
  • les holt's Avatar
  • Vendor
29 Jun 2012 12:11
#532612
Cool! I almost went with the separate oiling system on my Z1R, may still do it when I get back on that project. As for no boost now, I'd check the wastegate also.
Les
  • adam90xj
  • adam90xj's Avatar
30 Jun 2012 23:06
#532906
<---- Needs more details. I've been building a budget Kz650 with Kz750 engine that I plan to turbo with a blow through setup. What carb/ignition setup are you using?
  • jeffasaki
30 Jun 2012 23:13
#532909
budget and turbo shall not be uttered in the same sentence
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
The following user(s) said Thank You: guitargeek, wireman
  • kzz1king
01 Jul 2012 23:25
#533221
adam90xj wrote: <---- Needs more details. I've been building a budget Kz650 with Kz750 engine that I plan to turbo with a blow through setup. What carb/ignition setup are you using?
Mikuni 45
Dyna S and Dyna coils
