83 KZ750 LTD Cafe Project
- Rainman
- and a little Kaw shall lead them
Re: 83 KZ750 LTD Cafe Project
21 Mar 2012 14:55 - 21 Mar 2012 23:41
Welcome ColoPirate, I like the direction you are going with your LTD.
Similar to this
If you have not already checked the stearing lock to lock, this is what you are going to find
Remedy is to block the stops, dent tank for clearance or change tripple tree to non LTD standard with more fork offset. I will be changing the tree.
Also the LTD brake MC works if using clubman bars (tight but workable).
Good luck,
Jim
Similar to this
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
Last edit: 21 Mar 2012 23:41 by Rainman.
- ColoPirate
21 Mar 2012 15:49
apbling - I used this mostly
www.homedepot.com/Tools-Hardware-Hand-To...gId=-1&storeId=10051
it worked good to get it to the shape i wanted, then i used a 80grit sandpaper for a smooth finish. one of my pictures shows me using the tool i think. If i make another, which might be next winter, i will use florist foam, it seems to carve easier, the pink foam took a little more work. I also used high strength spray glue for gluing the layers together, which melted the foam a bit, so if you try it get some of the lower strength stuff.
Rainman - very similar! I think with the drag bars my controls are hitting the tank before my triple tree, but when i switch to clip-ons (when i feel like spending another $150) i will have to look for that. what did you use to block it? im having trouble figuring out the picture.
Denver, CO
1983 KZ750 LTD
1983 KZ750 LTD
- apbling
21 Mar 2012 17:36
Hey Rainman, did you make that cowl or get it from a different bike? Also, is your frame an LTD or standard?
- Rainman
22 Mar 2012 00:00 - 22 Mar 2012 00:15
ColoPirate, No blocking yet, I will be swapping the tree for one from a standard (78 KZ650C2) with more forward fork offset.
apbling, the tail is a chopped up tailpiece from a 79 KZ750B4 twin. Yes it started life as a LTD (80 KZ750H1), with slight frame tail chop.
Jim
Quincy,IL
Jim
Quincy,IL
Last edit: 22 Mar 2012 00:15 by Rainman.
- kozaz
- kozaz
10 Apr 2012 00:22ColoPirate wrote: So after all that this is where I am at, did some more bondo, mounted a new headlight bracket, made a license plate holder, and primed the tank and seat so I can find all my imperfections. It still needs some bondo work but it's closer
ColoPirate, where did you order your tank from? Is it metal? Looks fantastic!
Ryan
- blankdeluxe
17 Apr 2012 12:48What tank is that? I have been working on my LTD cafe build this spring and I'm still trying to find a good tank that will look better on my bike.
Give me all the bacon and eggs you have.
- Rainman
17 Apr 2012 14:27 - 11 Jul 2012 14:16
Jim
Quincy,IL
Jim
Quincy,IL
Last edit: 11 Jul 2012 14:16 by Rainman.
- ColoPirate
05 Jul 2012 17:40 - 05 Jul 2012 17:42
Sorry, been a while, moved, been working on some stuff...
the tank is from a GPZ750, i think it was even the same year, or close to. its an 81-84 i believe. and yes it is metal. I found it on ebay.
Denver, CO
1983 KZ750 LTD
1983 KZ750 LTD
Last edit: 05 Jul 2012 17:42 by ColoPirate. Reason: additional info
- ColoPirate
05 Jul 2012 17:52small update, i made the leather seat. I went to a local (littleton, co) fabric place and got some black leather. then for closed cell foam i went to big5 sporting goods and bought a camping sleeping pad for like 5 bucks, cut a few layers out of it and glued them together. so far it works good, but i might have to add to it.
Denver, CO
1983 KZ750 LTD
1983 KZ750 LTD
- ColoPirate
11 Jul 2012 09:04
So, finally got down to messing with the carbs, since I went with the pod filters I will have to replace the jets. Stock jetting was at 90 65, and I have been told to start with the main, so I am going to start around 130 and tweak from there. Right now the pods are the only change, still have the stock 4 into 2 exhaust, but I am in the mile high city, so elevation is a factor. Wish me luck, I will keep everyone posted best I can.
Side note, my buddy also works with a car wrap company, and is coming by tonight with some vinyl, similar color to what it is now, and we are going to wrap my bike, we will see how that goes as well.
Denver, CO
1983 KZ750 LTD
1983 KZ750 LTD
- ColoPirate
12 Jul 2012 01:04
So tonight i changed the main jets to 130 and gave it a spin. it seems to run good, i didnt notice any gas smell, but i am going to give it a little ride tomorrow and see if the spark plugs are dark and its running rich.
My friend came by and helped me out with a vinyl wrap for the bike, it wasnt easy but we got it on there. lots of heat from a heat gun, or hair dryer, and some stretching got it smooth for the most part. we had to make a couple cuts, i just have to figure out how i am going to cover them. here are some pics
Pulling over the tank
some more
side covers
some placement
finished product
one more, you can see a cut on the back side of the tank
some more
side covers
some placement
finished product
Denver, CO
1983 KZ750 LTD
1983 KZ750 LTD
