THIS TIME ITS A DRAGBIKE
- JEFFG1
Re: THIS TIME ITS A DRAGBIKE
30 May 2012 08:45yes that is where they come from . i ride the bike by myself so they hold up pretty good if you was to hall someone they mite not be that good but the price is rite and they look good4TheKZ1000 wrote: the shocks on the orange bike....did you get those off of ebay
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
- 4TheKZ1000
30 May 2012 08:50
ya they look nice and I was going to get a pair but was woried that they would be to soft as I am limited with the amount of rear travel I have. Very nice bike you have.
- JEFFG1
30 May 2012 08:58 - 30 May 2012 08:58Attachment Picture053.jpg not found
Attachment Picture054.jpg not found
Attachment Picture057.jpg not found
Attachment Picture059.jpg not found
Attachment Picture055.jpg not found
well i got the head back from having it milled for the ape cam chain tower and i put my jig on it to drill the holes fits perfect. a friend is coming down to build the motor in the next few days cant wait to get it on the track. also had to mill the valve cover i almost hate to run this head it looks so pretty.
Last edit: 30 May 2012 08:58 by JEFFG1.
- JEFFG1
07 Jun 2012 12:53
wondering what eveyone uses to seal the motor cases with ?????
- StreetfighterKz
07 Jun 2012 16:18
I've always used Yamabond #3 or #4 (I can't remember). Always worked good for me. I made sure I had a dry, oil-free surface when I applied it.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- mark1122
- Keep twisting it
07 Jun 2012 16:42
i use Permatex black rtv silicone on most things. as long as u understand the pros and cons it works well.
the reason i like it so much is that its easy to remove . if u r the kind of guy that has covers and things off a lot you will appreciate that. u can usually re-use the gaskets if u use this suff. the down side is that u need to pay attention to how much u put on. if u gob it on and tighten the covers, it will squeeze out on both sides(inside and outside the motor). i have heard reports of guys finding bits if the silicone on the oil pump screen.
i love that the tube has a long thin cone type tip. i can cut it to produce a thin1/16" film on the parts. when i'm done i don’t recap it. i just squeeze out about a 1/2" of silicone and let it drop down to the cap, then let it dry. when i need it again, i just pull this 1/2" piece off and i'm good to go.
I like yamabond or 3 bond too, but not as much as Permatex for gaskets.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- JEFFG1
11 Jun 2012 11:04
well started putting the motor together its been a long time coming. put the ape crank studs in,set the welded crank and had snitz mill the center cap and put the falicon plate on top of that.moved to the snitz racecut trans
put the extended kicker shaft in used the yamabond to seal the cases had to pull the spring and coller off the kicker wont go together with it all together i didnt know that learning as i go.
put the wisco 1260 13-1 pistons on the rods boy them clips are a bitch to put in, blood all over
put the mtc lockup in flipped the motor on its side and put the oil pump in and oil pan
well that is about it for the day will work on it tonite after work
got to looking at the ape starter plate didnt like the looks of it so taped it off and got out the paint
Attachment Picture060.jpg not found
Attachment Picture061.jpg not found
Attachment Picture064.jpg not found
Attachment Picture063.jpg not found
Attachment Picture065.jpg not found
Attachment Picture067.jpg not found
Attachment Picture075.jpg not found
- wireman
11 Jun 2012 11:18
Im liking it!
- z1kzonly
11 Jun 2012 14:06
Hi, fill me in on the extended kick starter shaft!!
That's brilliant! Used for the sidewinder clearence??
Did you weld one up? or is it out of a different engine?
- JEFFG1
11 Jun 2012 14:43i didnt want to put a starter and all that stuff on it so a friend had one of them that he welded up as you said it wont hit the pipe i have a pic in here some place hope it worksz1kzonly wrote: Hi, fill me in on the extended kick starter shaft!!
- JEFFG1
14 Jun 2012 08:53
guy at work brought in a hone and we got that done got home and my son and i put the jug on. man i looke down the plug hole and the pistons are super close to the head i have a 43thous head gasket on it, i am going to have to figure out how to make sure the valves wont hit??? it seems like a pain in the ass to bolt the cams in ect just to role it over to check but maybe thats not how you do it,the pistons are 13-1 with the j head i would think there would be room in there maybe someone has done this and knows if there is a problem. the cams suck they are only 380 lift so the valves wont be opening that much i wouldnt think
Attachment DRAGBIKE293.jpg not found
Attachment DRAGBIKE294.jpg not found
- wireman
14 Jun 2012 10:17
Get some clay strips to put on top of your pistons and in the valve notches to measure after turning motor over.
Is the outer edge of highest piston flush with top of deck? they look pretty close.
You could a shim up the bottem of cylinder to gain a little clearance if needed.
