'78 KZ1000 makeover
- Powerstroke_fan
Re: '78 KZ1000 makeover
04 Aug 2013 09:22
sorry porchev914, i thought above you said you only ordered one, Thats why i said that. Your engine is looking real nice so far.
1977 KZ 1000 work in progress
- porchev914
04 Aug 2013 14:56
No apologies man, my post was ambiguous. I did say I was waiting on one particular 18mm o-ring to assemble the cases. I would have made the same assumption
FRANKEN Z!
- porchev914
05 Aug 2013 02:21
I drug my freshly painted frame into the house and laid out a harbor freight $6 moving blanket and wend to work this afternoon :woohoo: First went in the assembled bottom end:
I seemed to have misplaced some of the bottom motor mount hardware, so I made some new ones out of stainless nuts and some 1/4" stainless rod. Stock on the left, my stuff (including a titanium motor mount plate) on the right:
Then I got the rear suspension bolted up:
Followed with the front end:
FRANKEN Z!
- porchev914
05 Aug 2013 02:26
Once my Z1E order shows up tomorrow or Tuesday, I'll get the pistons and jugs on. For those who have assembled these engines before, what's your take on copper coating for the base gasket? I've heard it both ways, and I definitely do NOT want a base gasket oil leek!
FRANKEN Z!
- Harvey1327
05 Aug 2013 02:46
Looking good mate. I have a copper base gasket which does not leak but I used the standard head gasket as the copper head gasket always leaked no matter how or what sealant I used.
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
The following user(s) said Thank You: porchev914
- testarossa
05 Aug 2013 07:42porchev914 wrote: Once my Z1E order shows up tomorrow or Tuesday, I'll get the pistons and jugs on. For those who have assembled these engines before, what's your take on copper coating for the base gasket? I've heard it both ways, and I definitely do NOT want a base gasket oil leek!
I did the copper coat on mine when I put it together. I haven't had any leaks around the base gasket at all. I did spend a bunch of time making sure that the mating surfaces were perfectly clean before I assembled it.
BTW the bike is looking spectacular!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Powerstroke_fan
05 Aug 2013 08:02
I put mine together and my base gasket leaked bad. So i bought some gasganich as suggested by cometic gaskets. Of course iam bored out to 80mm also, but i really hope its stops the oil leak. I will hopefully be putting the top end baxk together tonight.
- 79MKII
- Love Them Kaws!
05 Aug 2013 10:14
That looks awesome! It's exciting to see it coming together. :woohoo: I'm sure you're a little excited too! :lol:
The Kaw List:
05 Aug 2013 11:09
i copper coat base and head gaskets usually.
unless i have some kind of a good reason not to.
like the gasket has sealer made into/onto it.
nice progress keep up the good work.
- porchev914
05 Aug 2013 13:05
Thanks for the kind words my friends
Considering Leon has built a bajillion engines, Josh is every bit as picky as I am and powerstrokes' experience, I think I'll get a can of copper coat. The last thing I need is oil leaking on my brand new bike!
Now Leon, is the copper frame so terrible? I know it's not black, but it's gotta be a close second
FRANKEN Z!
- porchev914
06 Aug 2013 03:42 - 07 Aug 2013 09:24
OK, pistons on:
I did copper coat the base gasket, and will likely treat all the gaskets the same.
Then went on the cylinder, which by the way, was a PITA. I put the head on just to keep it closed up. I did lay the tank back on it to see how it would look.
I didn't take pictures, but I replaced the center cam chain roller in the block and its rubber dampers with new OEM parts. I also replaced the rubber tensioner roller and the front plastic rubbing block with OEM parts as well as the idler gear rubber dampers. I did not replace the idler gears, as they seemed to be in good condition with no slop and smooth bearings.
The head is going to come apart so that I can replace the valve springs and stem seals. While its apart, I will clean up the intake ports a little and smooth out the exhaust a touch. Just blend things in a little, nothing crazy or drastic.
Tomorrow I'll put the subframe and battery box on, then it'll look more like a complete motorcycle.
FRANKEN Z!
Last edit: 07 Aug 2013 09:24 by porchev914.
06 Aug 2013 10:10 - 07 Aug 2013 10:10
man i don't know what to think about all this progress :evil: !
dayum son you been getting some work done.it's almost like you are planning on finishing this project up or sumthin :whistle: .
yeah the copper is better than blue,red,yellow,or green thats for sure.
it kinda goes with the forks too
we are watching you sir ...
Last edit: 07 Aug 2013 10:10 by 531blackbanshee.
