Testarossa's 78 KZ1000 Fighter Build
- mark1122
- Keep twisting it
Re: Testarossa's 78 KZ1000 Fighter Build
28 Sep 2010 14:49
testarossa wrote:
good idea, that should work nicelt.
mine is mounted on the front of the inner fender.
mark1122 wrote:i mounted my Dyna side ways so that i could
1. access the knobs, by removing the right, side cover.
2. so i could see the timming signal light, that is located on its end, while turning the crank by hand with a wratchet.
I started out trying to do it the same way, but it's a little too high to reach the knobs. They get obscured by the frame tube. I'll mount it front to back with the velcro. That way, I can remove it easily for timing purposes.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
28 Sep 2010 20:56
Ok guys, I got the Dyna mostly wired up this evening, and I finished with all the new bullet connectors to make the headlight wiring permanent. All that's left of the wiring is to get the crank trigger attached and shrink wrap the harness. Closer and closer to starting the old girl!
I'll tell you this much. All that neck bracing doesn't make installing plug wires any easier.
Here's the Dyna mounting pics:
A couple of shots of the lights:
I took a couple of crappy videos with my camera, and once I figure out how to post them on youtube, I'll link them here.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- testarossa
28 Sep 2010 21:38
Lets see if these videos will post:
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- Nelson
28 Sep 2010 22:47
I dig that flashing! Anybody who runs into you is drunk or texting.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- camaroguy
29 Sep 2010 03:03
Ilike that tail light.looks very bright.Iam just about in the same place you are with my wiring.spent about 4 hours in the garage saturday only to get just the tail light brake light working.I looked into my wiring diagram and the wiring colors flipped on me right at the starter solenoid.swapped them around and voala it cranks. also my bike has some reserve lighting deal.finally figured that out.what did you come up with to provide a temp. gas supply?I am running for now just the stock ignition. checked it last night with plug out while cranking and I have a pretty decent spark.will be refering back to your install of the dyna in the future.
- mark1122
- Keep twisting it
29 Sep 2010 07:31 - 29 Sep 2010 07:32
Very cool. i like the flashing.
i've forgotten? did u post all of whats involved for that led conversion and flasher, in here somewhere?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Sep 2010 07:32 by mark1122.
- testarossa
29 Sep 2010 07:46
mark1122 wrote:
Mark, I showed the physical mounting stuff, but not the wiring. It's really simple once you figure out which wires on the new taillight operate which functions. They didn't send a detailed wiring diagram since it had the connectors to plug into the R6 factory harness. I actually hardwired it into the original KZ taillight connector, so it plugs in just like a stocker.
Camaroguy, I will steal the gas tank off my son's go-kart for a temp. fuel source. He will be pissed off at me for it, but he can deal for a couple of days. That kid doesn't miss anything.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- trianglelaguna
29 Sep 2010 08:03
nothing like getting closer to starting it up.....slow...then fast.....then it slows down again...then one day your close...like you are now...way to stay on it....time to boogie down soon....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- mark1122
- Keep twisting it
29 Sep 2010 08:15
testarossa wrote:
mark1122 wrote:Very cool. i like the flashing.
so u bought a plug in led unit for the r6 lt?
did u need anything else to make it flash?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
29 Sep 2010 08:30
did u need anything else to make it flash?[/quote]
No, the taillight included the sequential flaser unit. I actually seems to work with either a constant 12v input or with the pulsed input from the standard flasher can. I currently need the regular flasher to operate the front turn signals, so the taillight gets the pulsed 12v from the normal KZ wiring. It even keeps time with the front turn signals.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
29 Sep 2010 10:20
I see.
It looks great. well done.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
29 Sep 2010 20:20
Well I finished wiring up the Dyna this afternoon. I couldn't really do a better job of describing how to do it than the instructions. The wiring is straightforward in my opinion. I did notice one thing confusing about the timing instructions, so I'll walk through that in case anyone else plans on installing this ignition.
First you remove the stock timing cover and all the components of the points ignition. Next you replace the stock rotor with the one that Dyna provides:
Then you install the Dyna crank trigger plate:
Leave the screws loose at this point so you can rotate the plate when timing the bike. Make sure to connect the four pin connector to the main harness for the ignition.
Next it instructs you to remove the spark plugs and rotate the engine until the trigger for cyls. 2 and three lights the LED on the control box. Then you rotate the plate until the the led is lit at the 40* mark. Now you tighten the three mounting screws and lock the timing in place.
I set my control box atop the clutch cover to see the LED while turning the engine.
With the timing correct for 2 and 3, you move on to adjusting the timing for 1 and 4. Here's where I was somewhat confused. It says to rotate the engine 180* to the same 40* mark for cylinders 1 and 4. You are then supposed to move that particular sensor to light the LED. I couldn't tell from the instructions, which sensor was for 1 and 4. I just tried one and of course it was wrong. Then I had to re-do 2 and 3. Now back to 1 and 4. The proper sensor to adjust is the left one that I pointed to in the next pic:
Now you just replace the timing cover and secure the wiring. The static timing is complete, and you should be able to start the bike.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
