Testarossa's 78 KZ1000 Fighter Build
  • T_Dub
  • T_Dub's Avatar
Re: Testarossa's 78 KZ1000 Fighter Build
17 May 2011 14:57
#451730
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
17 May 2011 15:06 - 17 May 2011 15:08
#451732
nelson,
pictures tell a thousand words.you have been working on these bikes long enough to look at some good pictures and pic out 95 percent of what has been done.
japanese does not translate very well(although googles language tools try to).
here is sanctuary's blog index.there are seven,i have been through four of them.so now i am off to see some more :lol: .
www.ac-sanctuary.co.jp/blogs/index.html
Last edit: 17 May 2011 15:08 by 531blackbanshee.
  • testarossa
  • testarossa's Avatar Topic Author
25 Jul 2011 23:22
#464937
Wow, it's been 9 weeks since I have updated this thread. As promised, I have been riding, and doing all the usual summer stuff with the kids. Juggling numerous other side projects. Well since I have about 10 balls in the air, the KZ ball was bound to come back down eventually. If you remember that thread that I started about the chopper frame here: kzrider.com/forum/11-projects/461220-chop-till-you-drop The main reason that I bought that project was for the mostly complete 1015cc KZ motor that was included.
So I decided to try and re-organize the garage today, so I can start tearing into the CB750f. The KZ motor is currently an obstacle to that effort so, I started to tear into the thing this evening. Wow that thing is dirty. So the PO already had the head off, and I got the jugs pulled easily. Pistons are off, and the good news is that the jugs are in good shape. No busted fins, and the bores are good candidates for a 72mm bore. Pistons don't look too bad either, but are worn. The bad news is that I don't have great hope for the head. It does have broken fins on one corner, and all of the timing chain tensioners are torched. I wonder what sort of shape the valves are in? That's no matter anyway, this will make a perfect practice head when I finally get my DIY flow bench built.
Hopefully I can get the rest of the motor dismantled tomorrow so I can organize and store parts. All I really need is the jugs, so I can clean them up and they will be off to be bored once I get the new pistons. We'll see how tough that alternator rotor is on this motor. :evil: Does anybody want to see pictures of nasty engine bits? I guess the tensioners will be interesting to look at. Looks to me like someone kept going after the ugly noises started in there. This one looks like it broke off in there and got spun around by the chain for a while:
Attachment z1-cam-chain-guide.jpg not found
I'll try and get some pictures tomorrow for the interested parties.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • trianglelaguna
  • trianglelaguna's Avatar
26 Jul 2011 01:19
#464972
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • testarossa
26 Jul 2011 23:49
#465194
Got the rest of the spare motor dis-assembled tonight. Once again the old top clamp bolt and 1/2" drive impact gun did the trick. I must just have the most alternator ass kickin, clutch hub nut bustin, counter sprocket nut bustin, cheap ass impact gun ever. I got all three busted loose by holding the part with my left hand and the impact gun did the rest. Just cranked up the air regulator to 120 psi and let her rip. I still feel like everyone has a hard time with the alternator due to the use of long bolts. That top clamp bolt is short and wont twist to absorb the impact like a long bolt will.
Typical 30 year old KZ motor, it's cleaner inside than out. Trans, clutch, and crankshaft "look" good. I haven't measured anything, and won't for a while, but based on appearances, it's good. However, like I said yesterday, the cam chain rollers are roached. Have a look:
Attachment 0726012016.jpg not found
Attachment 0726012017a.jpg not found
Compare that one follower to the picture of the new one from last night. It broke off at the screw on top and the bottom broke as well. Looks like that chain was bearing down on that guy for a while. Guess that's why Larry always advises everyone to replace this stuff when you are in there. I know it adds up, but I bet this one was lucky that the chain didn't skip and crash the valves. I can't find any marks on the pistons, but I haven't even looked at the head yet.
2004 ZX-10R
Angola, IN
  • 531blackbanshee
  • Vendor
  • Vendor
27 Jul 2011 00:46
#465206
good catch man.if that went much longer i bet things would have gotten real ugly.although these are some tuff engines.
  • testarossa
07 Aug 2011 00:10
#467374
I decided to start cleaning up the cases for the spare motor. Started by soaking those dirty things with a little ATF. This seems to break up the grease fairly well. Then I found a good shade tree to set up under and let fly with the pressure washer. Not shiny and beautiful yet, but at least they aren't nasty and greasy. Nothing cuts grunge like 2600psi.
Before:
Attachment aP1010464.JPG not found
Attachment aP1010465.JPG not found
After:
Attachment aP1010467.JPG not found
Attachment aP1010466.JPG not found
2004 ZX-10R
Angola, IN
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
07 Aug 2011 19:06
#467540
Man ur gonna have your hands full with all of these new project bikes.
Have fun with them bud.
what did u use for the shifter linkage ? the part that atatches to the shifter shaft. 83 GPZ ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
07 Aug 2011 22:09
#467578
mark1122 wrote: Man ur gonna have your hands full with all of these new project bikes.
You got that right. Did I mention I bought a boat also?
I made the shift linkage. Initially, I tried using the linkage from the 95 GSXR, but the splines are different. I ground it out a little, but then I couldn't get it tight. I tried searching for a link on ebay, but when I realized that getting the spline right would be a crapshoot, I decided to make it myself rather than pay $30 a piece for links that may or may not work. Here's a couple of new shots so you can see for yourself.
Attachment aP1010471.JPG not found
Attachment aP1010472.JPG not found
Attachment aP1010473.JPG not found
2004 ZX-10R
Angola, IN
  • trianglelaguna
07 Aug 2011 22:27
#467585
i like em better for sure...very very clean...the bike is clean too...very nice...a lot of work...nice
1976 KZ900
2003 ZX12R
2007 FZ1000
  • porchev914
  • porchev914's Avatar
08 Aug 2011 00:47
#467627
Wow, does that bike look nice! I too like the new rearsets, but I may need to build mt street cred back up after being MIA for so long....
FRANKEN Z!
  • Nelson
  • Nelson's Avatar
08 Aug 2011 00:48
#467628
crap. I'm still trying to figure out why I don't own a pressure washer... sure woulda been handy but too late now.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
