Testarossa's 78 KZ1000 Fighter Build
  • testarossa
  • testarossa's Avatar Topic Author
Re: Testarossa's 78 KZ1000 Fighter Build
13 Apr 2011 10:57
#444406
I was discussing that with a co-worker this morning. It's exactly the sort of part that we make all the time in our shop.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
13 Apr 2011 10:58
#444407
this is gonna be a cool thread!
:evil:
i can't wait to watch you rehab these turds into the polished jewels that i know you will have.
  • testarossa
13 Apr 2011 11:22
#444408
As long as I can get the mechanical issues sorted, I will spend some time polishing on these carbs. They are worth the effort, unlike those dang VM26's that are on there right now.
2004 ZX-10R
Angola, IN
  • testarossa
13 Apr 2011 13:55
#444420
BTW I forgot to mention that I did the valve clearance checkup, adjusted the timing chain tensioner, and went over all the nuts and bolts on the bike. I also pulled the carbs and re-did all the passages, and I still can't find anything plugged there. Stuck it all back together and I also installed the straight through baffle that I built so long ago.
Still has the hiccup just off idle, but not as bad. The small vibration changed, but still there. However, on the bright side, that new baffle made a world of difference. I had to step up a pilot jet size to 17.5 and the bike has a ton more midrange power now. Not to mention that it was engine braking so hard before that it felt like I had a Jake Brake on the bike. Now that's gone. I guess that the previous baffle was too restrictive.
2004 ZX-10R
Angola, IN
  • testarossa
14 Apr 2011 19:49
#444637
Phase one of the carburetor repairs is done. I got those dumb ez-outs and the remains of the two pilot jets drilled out from the carbs. Here's how I went about it. First I clamped the carb body in a mill vise and indicated the ID of the counterbore above the pilot jet. This ensures that the drilling is on the centerline of the jet. That's important because you don't want to drill out the threads in the carb body.
Attachment a0413011544b.jpg not found
Next, I needed to use a carbide endmill to drill out the hardened tool steel ez-out. I had a worn 1/8" ballnose so I used that and drilled down until I couldn't see any more of the ez-out. You can just see the endmill above my indicator in this picture:
Attachment a0413011508.jpg not found
Now the next trick is to find a left hand twist drill bit. Sometimes you get lucky and the bit grabs the broken screw or jet and just unscrews it. I didn't get so lucky this time.
Attachment a0413011529.jpg not found
I had to keep drilling to just under the size of the minor diameter of the threads. I measured the minor diameter with a gauge pin at 0.163". I drilled up to 0.161" and then I carefully picked out the last slivers of brass. After I thought all of the brass was gone, I made up a small brass bolt to screw into the carb. This bolt has a slit cut in the end to clean out any remaining junk. The correct thread is M5x0.8 by the way. The end of the jet fell out when I drilled through it:
Attachment a0413011539.jpg not found
2004 ZX-10R
Angola, IN
  • wireman
  • wireman's Avatar
14 Apr 2011 20:13
#444638
that looks fancier than my milwaukee 18v cordless drill press! :woohoo:
  • testarossa
14 Apr 2011 20:20
#444643
I also got one of the jet blocks repaired today. First I was concerned that I may smash the jet block since it is very thin aluminum. So I made up an aluminum slug that fit tightly inside the jet block to support it. You can see the slug in the jet block in the following picture. Notice that I indicated the boss where the jet needle screws into.
Attachment a0414011525.jpg not found
Now I used a 5/16" endmill to mill out the messed up threads. This particular mill has a little play in the spindle bearings, so the hole actually came out to 0.317" but was round to within 0.0002" so I called it good.
Attachment a0414011532.jpg not found
Next I made up a brass insert on the lathe. This insert must be precisely sized to produce a light press fit into the bore in the jet block. I cut the insert to 0.3174" and drilled and tapped it for the M6x0.75 threads that are supposed to be there. Here's the insert before I installed it:
Attachment a0414011613.jpg not found
Finally, I just pressed the insert into the jet block. I just used a small precision vise since this is a light press fit, no need for the 50 ton press. This is the part where I felt the need for that aluminum slug. I was concerned that I may distort the jet block when pressing the insert in place.
Attachment a0414011619.jpg not found
Now I just have to do the other three..
2004 ZX-10R
Angola, IN
  • wireman
  • wireman's Avatar
14 Apr 2011 20:37
#444648
show off! :laugh:
  • testarossa
14 Apr 2011 20:47
#444651
wireman wrote: show off! :laugh:
Hey, I'm not showing off. This is my application for the new machine shop foreman at Zmax! :)
2004 ZX-10R
Angola, IN
  • wireman
  • wireman's Avatar
14 Apr 2011 20:52
#444653
the "press" in my milwaukee cordless drill press comes from me pushing on it! :sick: :woohoo:
hopefully ill here something back tomorrow about the building down the street,then ill have some room to spread out and buy some bigger tools for shop. B)
  • rslingshot
  • rslingshot's Avatar
14 Apr 2011 21:16
#444656
Nice work Josh! Thats what I like some real detailed work keep them pics coming.
14 Apr 2011 21:21
#444659
Yikes! :ohmy: Those pilot jets were stuck in there really tight! :pinch:
Kudos for a job well done on removing them. :cheer:
:unsure: Just curious as to whether it might be beneficial to "heat" the jet block and "freeze" the new brass insert immediately before putting them together, with a view toward eliminating the need for any pressure (akin to method for bearing fitment). :unsure:
Once assembly is completed and temperatures normalize to tighten the fit, they should remain tight during service where temperature of both remains equal.
No doubt you will soon deserve your very own parking spot. :lol:
Good Fortune! :)
