I know that this has been gone over several times before (I did a search in the forum). But I can't find the answer that I'm looking for. The project I'm working on is a 1981 KZ1100 shaftie frame with:
1982 kz1000 motor (chain drive)
1979 kz750 twin front forks and wheel/brakes
1981 xs650 yamaha triple tree
198? honda vlx600 swing arm and mono shock
19?? yamaha R1 rear wheel (6" x 17" with a 190 tire)
Those are some of the basics on this build. The reason for the shaft drive frame is more room, so I didn't have to modify the frame for a wide tire (that and it was cheap).
I bought a 5/8" offset sprocket from PMF, and have a 530 chain (tsubaki), going to run the R1 rear sprocket.
I made the appropriate spacers to fit the swing arm in the frame and am try to get everything in line, the wheel is offset to the right 3/8" (can only go over to the left about 1/4" before the chain hits the swing arm). With this setup my 5/8" offset sprocket needs to go to the left an additional 3/16" to be in line with the rear sprocket.
So on to the question, where am I going wrong. Is it ok to run the rear tire 3/8" offset to the right? Should I order the 7/8" offset sprocket? I'm a machinist and can make any spacers that I might need to get this project done.
Your help, and comments are greatly appreciated
