I started the day off removing the cam covers and checking the cam caps and retorquing the head bolts.
I took care of one oil leak at the oil pressure sending unit. Then i thought i would install the 34 mikunis.
Every thing went down hill from there.
I removed the small boots installed the big one. Looked for 30 minutes for the bracket that holds the throttle cable.
Finally found that and installed carbs.
Two friends were waiting on me so we could ride.
Fired bike up and the carbs leaked and bike wouldn't idle. Probably pilot jets stopped up.
Bike dies. One friend says he seen smoke come out from under rear fender. Sure enough the PO ran the tail light wires between top of frame and rear fender. Unplug wiring harness install fuse. Bike fires. Bike dies. Pull Tank off and the plug to the coils has pulled apart.
Tell friends to go ride.
Rewire bike front and rear. Remove big carbs and boots.
Install 28mm and boots. Bike misses on number 1. Check wiring change plug change plug wire.
Ride bike to town to get a new plug. Bike runs great at 5000 Rpm.
Get to parts store and buy two plugs. Bike misses on no.1
Rewire coils again. Bike misses. Started to pull the pod filter off no. 1 and the carb boot is not tight.Go in store and buy metric allens. Remove carbs and tighten boots.
And i tell poeple not to getin a hurry.
Then i had a nice little ride.Roy
