- Thank you received: 3
1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
- SeattleKZ
Couple questions
what's length on the rear shocks?
are those 17" wheels?
- tk11b40
- Thank you received: 21
fully extended 13.5" center to center eye to eye.
Yes they are 17 inch wheels, Front from an early 90's GSXR, rear from a 99 ZRX 1100.
Thank you for the compliment, you appear to be from Seattle, I was living in Wenatchee until 2007.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- SeattleKZ
- kaw-a-holic
- Thank you received: 249
ytk11b40 wrote: This is a great idea, except for the copywrite problem.
The points cover, would be easy to make, 1 lathe Op, 1 mill op. I just need a different Logo.
I will look into this, the part is possible.
The KZR logo would me a bitch'n points cover. I have also considered cutting out the center and putting plexiglass in the center with some LED back lighting.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- tk11b40
tk11b40 wrote: Rear shocks:
When you are ready just hit me up. I can walk you through the swingarm switch. The 99 ZRX fits right in. Then there is the chain alignment, and the front and rear wheel alignment.
Its all do-able.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- SeattleKZ
- Mickey1031
- Thank you received: 1
but i have seen several on here that have changed the rear swing arms from the early gsxrs to the KZ.
can you let me know if you have build thread on your bike? ya have me thinking of doing something like this instead of the fight for a title etc... on a totaled bike. besides i got the whole thing for 300.00 because of the no spark issue so tearing it apart might be even more fun then trying to rebuild it
The difference between a "biker" and a real Biker, saying you own a bike, and actually owning a bike, Not a "T" shirt
- tk11b40
I did not have that luxury so that you can compare measurements easily. I do have a good friend with a ZRX so we did a great deal of measuring before we started the swing arm swap.
I have seen a few KZ's with the Gixxer motor installed, it seems to look reasonable. Winter is coming it is time to start on the KZ project again. Ten years now I have been working on this thing.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- NakedFun
- Thank you received: 121
SeattleKZ wrote: Cool thanks man. Unread skittle but of this thread and saw that aligning all that stuff can be a challenge but it's good for me somebody already did it.
If you ping Leon (531BlackSheep) I think he is making a shaft I designed to slide the ZRX swinger in place in the KZ chassis. Just need to slice about 1/8" off the right hand side of the swinger pivot tube and push the seal in until it is flush. Slide this shaft in place and run two grade eight 5/8" bolts in from either side and your done. Then comes chain alignment....
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
- tk11b40
This should kill track days on the R6 and the KZ project for a few months.
I am betting this is the longest running KZ project in history. I have refurbished at least three other bikes while the KZ project has been going on. Not to mention basically resto-modding the S2 Gixxer.
Looks like I will be pulling the stock KZ carbs and taking a second look at why the number 4 carb is jacked up.
Here is an interesting site if you love the KZ:
sbkfactory.com/
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
Here is a little video my buddy Dave made of a ride we did last spring on the Playa in Nevada...
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
