1075 kit with cams...
  • saxjonz
  • Topic Author
  • KawboyZ
19 Jun 2013 10:23 #593043 by saxjonz
Replied by saxjonz on topic 1075 kit with cams...
You know? That IS the direction I'm leaning in and I was thinking billet aluminum clamping to frame too. I could always cut it later if it doesn't work for the esthetics.
79 LTD B3
  • bluej58
19 Jun 2013 10:37 #593046 by bluej58
Replied by bluej58 on topic 1075 kit with cams...
I'm jealous :lol: can't wait to see her running.
Leave the tank off until you get the brakes right.
Cute kid L.
JD
78 KZ1000 A2A
  • Dr. Gamma
19 Jun 2013 11:44 #593051 by Dr. Gamma
Replied by Dr. Gamma on topic 1075 kit with cams...
531blackbanshee wrote:
i would hate to have to cut the bracket off this pipe and re-weld another on.
a custom bracket that clamped to the (basically)vertical tube would be cool.
hard to describe tho :pinch: .
A great old Bassani Superbike pipe!!!! Most of the Bassani Superbike pipes sold were plasma coated before they were painted. Thats why you never had much rust on a Bassani pipe. I would not cut the bracket off the pipe. You will lose the coating around where you weld the new bracket on.
Your idea with the bracket to the vertical tube would be the way to go. Plus if you wanted to get real fancy, use the rear exhaust rubber dampners from like the KZ900 made into your bracket, and then your pipe would be rubber mounted too!!!
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: saxjonz
  • saxjonz
  • Topic Author
  • KawboyZ
19 Jun 2013 13:53 #593064 by saxjonz
Well, the two ideas were to cut the bracket and actually weld a spot on back of pipe so it's a very clean look utilizing the actual exhaust mount. The other was to make a bracket which I think would be the best idea and the third was/is to eaventually just find a 76 frame and weld up the frame really nice, powdercoat and swap parts. Probably a good idea. ;-) why not? After all it's only time.
79 LTD B3
  • saxjonz
  • Topic Author
  • KawboyZ
20 Jun 2013 19:38 #593264 by saxjonz
My package arrived today! Z1parts.net is the REAL DEAL. side covers look EXACTLY LIKE THE REAL DEAL.
I was really apprehensive but no worries. This place has the PARTS!
79 LTD B3
  • saxjonz
  • Topic Author
  • KawboyZ
24 Jun 2013 18:02 - 24 Jun 2013 18:04 #593748 by saxjonz
Just put most of the parts I ordered on yesterday. Need a few things...still need brake calipers in front and lines front and back and also need to make a decision regarding hydra vs cable. Leaning to getting that hydra piece installed. Also having a problem with the seat hitting the big tank and wonder if they just assumed that my LTD would have a small tank even though I stated clearly that I had retrofitted the big tank.
I hopefully should have pictures up soon of it after I take care of business.
Attachment kzrecent.jpg not found
Oh, and I think it was you Leon, the red battery box doesn't still poke you in the eye does it?
79 LTD B3
Last edit: 24 Jun 2013 18:04 by saxjonz. Reason: added
  • Forrest
  • The Mad Duck
24 Jun 2013 18:47 #593750 by Forrest
Replied by Forrest on topic 1075 kit with cams...
Looking real good Lawrence! Let's ride this weekend! If not our KZs then the Rexes! See you soon my friend.
  • KZJOE900
  • Administrator
  • Administrator
    Super Users
24 Jun 2013 21:14 #593776 by KZJOE900
Replied by KZJOE900 on topic 1075 kit with cams...
saxjonz wrote: Also having a problem with the seat hitting the big tank and wonder if they just assumed that my LTD would have a small tank even though I stated clearly that I had retrofitted the big tank.
I think a lot of people experience that even with an original LTD seat fitted to non-LTD KZ tank. I went to WalMart and bought a very small section of the velv'est, black velvet I could find. Cut out a section of it to match the seat front section that makes contact with the seat. Then used Loctite Superglue Gel . The gel type gives you more control and concentration of the glue. This has minimized the amount of noticeable wear of the gloss on the tank where it contacts the seat.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
25 Jun 2013 07:03 - 25 Jun 2013 07:05 #593835 by Old Man Rock
Replied by Old Man Rock on topic 1075 kit with cams...
The Corbin pan is polymer so with a little heat you may be able to reform the pan crotch tip at the tank every so slightly to better fit.....
NOTE: A LITTLE AT A TIME (couple seconds) W/THE HEAT...
Better yet.... You could also remount the seat hinges 1/4 to 1/2" back (or whatever distance required) away from the tank. ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 25 Jun 2013 07:05 by Old Man Rock.
  • 79MKII
  • Love Them Kaws!
25 Jun 2013 14:12 #593872 by 79MKII
Replied by 79MKII on topic 1075 kit with cams...
They sell those tank protector pads everywhere now...you could custom cut a clear one to protect the tank.....just another option.
The Kaw List:
  • trianglelaguna
25 Jun 2013 16:13 #593890 by trianglelaguna
Replied by trianglelaguna on topic 1075 kit with cams...
the seat wont rub on the tank unless the bike is running...so you should be good for a few more years yet
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • saxjonz
  • Topic Author
  • KawboyZ
25 Jun 2013 17:02 #593911 by saxjonz
The seat fits perfectly on the tank is just opening it and closing it the right side of it sticks on the tank. I think I'm going to send it back if I can't reasonably get it to close without rubbing.
79 LTD B3
