- Thank you received: 225
OMR: '76 KZ900 Restoration/Modification
- Old Man Rock
1) Set idle ~ 1800-1900...
(NOTE: Settles ~ 1400-1500 after slow jet (pilot adjustments for lean) for easier starting in testing.
2) Turn each pilot CCW Leaner in CR's ~ 1/2 to 3/4 turns.
3) Screw driver in back pocket, roll her out of testing bay, rotate back (CW Richer) the number of turns, set idle ~ 1000-1200 (I like her a tad higher to get the oil flowing)... All good!
This places her stoich lean @ ~ 14.7 - 15.2 as reviewed in the image.
No need for choke or anything, just press the start switch and she purrs to life.
NOTE Carbon monoxide, almost 0.00 .... :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Dr. Gamma
- Thank you received: 706
Stupid question for you...... I just moved down from Northern Arizona to the Phoenix area. They have emission testing for bikes in Phoenix????
Please say that ain't so. With any of my motors, there is no way in hell I will pass an emission test!!!
1986 RG500G 2 stroke terror.
- Old Man Rock
But no big deal any longer (for me anyways), I've learned the tricks to get her through emissions with no worries over the last 5 years...
You can register them as antique, w/insurance proof, less than 2,000 miles skips emissions.... From others I've spoken with, said it's kind of a hassle but as with your builds, no way in hell they can get through the test...
Where you located...?
I'm 55th & Greenway, Glendale, we;ll need to hook up.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2831
Old Man Rock wrote: Yup... Maricopa County is the only county in the state requiring emissions...
Sounds like a reason to keep a spare speedometer on hand for emission tests. :laugh: :laugh: :laugh:
- Dr. Gamma
Yea, would like to check out your KZ. Like that single shock setup!!!
Got to check out a map to see where you are it.
I am down near San Tan Valley. Near Ironwood and Octillo. I am like 5 miles south of the new dirt track on Ironwood.
- Old Man Rock
45 minute drive, no biggy... I'll PM you.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
