OMR: '76 KZ900 Restoration/Modification
26 Sep 2008 08:01 #238749 by gorack
Replied by gorack on topic OMR: '76 KZ900 Restoration/Modification
damn i thought i was building a clean custom bike, then i see yours, well gotta throw mine in the dumpster and start building a omr clone. seriosly beautiful bike can't wait to see finished
  • Old Man Rock
  • Topic Author
27 Sep 2008 11:43 #238941 by Old Man Rock
Replied by Old Man Rock on topic OMR: '76 KZ900 Restoration/Modification
Update: Forward controls stripped and buffed out....
Still not sure if I want to paint instead...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
  • Topic Author
27 Sep 2008 11:46 #238942 by Old Man Rock
Updated images with tank and new updates for color scheme...
If case you're wondering, I'm presently in the hold for funds phase (valve 3 way grind w/ port & polish) so just taking care of all the free but labor stuff during this period.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Bad Kaw
  • Flying Squirell
28 Sep 2008 06:46 #239029 by Bad Kaw
Replied by Bad Kaw on topic OMR: '76 KZ900 Restoration/Modification
Getting close!
Myself, I'd go with paint...or perhaps anodized...hmmmm. But it's your ride and you are clearly compatent.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • mark1122
  • Keep twisting it
28 Sep 2008 07:29 #239032 by mark1122
Replied by mark1122 on topic OMR: '76 KZ900 Restoration/Modification
STOP,STOP!
Every time i look at your new posts i hve to dry the drewl out of my keyboard.
As allways,Nice work.
I am going over my tank and sidecovers today with rubbing compound and wax,AGAIN.
Be AWARE! If you spill gas on Dupicolor Metalcast paint,you MUST go directly into panic mode to save it.
My gas cap was not on tight and when i left the gas station the gas spilled out over the tank and down the side coversI stopped right away and wiped it off, but it marks the surface right away.
Please be carfull with gas around that beautifull bike.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
  • Topic Author
28 Sep 2008 08:40 #239042 by Old Man Rock
Mark.... Did you follow up shooting a 2 part clear coat over the Metalcast as I posted on the painting of my tank?
And not can clear coat either for that crap sucks...
The Dupli-color paint products will not hold up to gas, nor did any other can paint I tried. Non of them held up nor would they and this is why clear coats
    MUST
be followed up on these can paints or any paint for that matter. Clear coat is not just for shine, it protects the paint under it...
I even tested a Sherwin Williams paint with no clear with GAS, yes, it held up slightly better than some of the can paints I tested but it did tarnish as well where rubbing compound would be required.
Again, paint alone will not hold up to gas...
I also tested can clear coats, non held up as well as a 2 part clear shot... I understand you can now buy clear in a can with a breakable hardner in it but as posted, the Prevail unit works very well for those w/out a gun and compressor.
@Bad Kaw,
Yeah, wasn't sure of the front end chrome effect either. I'm pretty sure I'll be painting the controls and head light the metallic orange to match the tank...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • mark1122
  • Keep twisting it
28 Sep 2008 09:09 #239046 by mark1122
That’s right; I forgot that u used the 2 part clear cote.
I painted mine 2 years ago. i used a high heat engine clear on mine, because it said it was gas resistant. Obviously its not VERY gas resistant. Anyways i hope my comments will be a good heads up for those who read this post and they will do as u did.
it is too late for me to use the 2 part clear , as my tank has many chips on it already. I need to start over now.
i will likely use automotive paint next time. it is just too hart breaking to go through this again. But, on a positive note. I am glad in a way, that i did this with the spray can. I don’t think it is possible to get every thing on the bike done right the first time. So I wont feel so bad when I have ruin the paint to have another part welded on here or there or modified slightly, since I didn’t pay a fortune for the pain job.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
  • Topic Author
28 Sep 2008 09:25 - 28 Sep 2008 09:26 #239049 by Old Man Rock
mark1122: Love ya my KZ brother....
I didn't say anything prior to this so figured this is a primo time to post. 3 months ago, I spray painted some angle Iron using the metal cast ground coat (metal flake primer) and Metal cast color for the EXTREME test.... Arizona summers!!!
For those of you that don't know AZ summers, 100-115 degree heat then we get Monsoons. The results in the image where taken ~ 5 minutes ago... And this is with no clear coat what so ever....
This piece has been sitting in direct sunlight, been rained on, dust storms you name it etc... No blistering, no peeling etc...
As posted numerous times, I post the good and the bad results, so no need to inform you otherwise...
CLEAR COAT your paint jobs.... :whistle:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 28 Sep 2008 09:26 by Old Man Rock.
  • Old Man Rock
  • Topic Author
28 Sep 2008 09:32 #239056 by Old Man Rock
...maybe not to late...
Wet sand the clear coat down to the paint then shoot the 2 part clear... Example, In my tank, I thought I had to buff out the paint prior to clear... Not so... The black was like gray in color and when the clear hit it it shined like a SonsABitch.
Worth a try... Hopefully were not speaking of you're latest pictures/paint work (Blue/Black/Gray).
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • mark1122
  • Keep twisting it
28 Sep 2008 10:28 - 28 Sep 2008 11:13 #239069 by mark1122
That looks like it stood up well.
My chips are in the red paint so u can see the silver coat underneath. i also have cracked glass like cracks all through the front of the tank.this may be due to useing the engine clear cote? any ways i will have to start over at some time.
My bike is red . This 1.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Sep 2008 11:13 by mark1122.
28 Sep 2008 11:01 #239078 by kzr750r1
Replied by kzr750r1 on topic OMR: '76 KZ900 Restoration/Modification
OMR
Now that they are polished go I vote for black anodizing.
Since the base is polished the result will be pure moto jewelry.
I regret not polishing all the bits I had anodized. Some of the really (un polished) little pieces turned out flat the others are high gloss.
As always great work and progress.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
  • Bad Kaw
  • Flying Squirell
28 Sep 2008 11:46 #239086 by Bad Kaw
OMR
Ewwww, that might look nice. Also I recently spied a very cool bronze anodize recently and it might go real well with your theme, including that head-light.
78 Kawasaki Z1R
70 Kawasaki KV75
