- Thank you received: 225
OMR: '76 KZ900 Restoration/Modification
- Old Man Rock
11 Jun 2008 17:47 - 11 Jun 2008 18:02 #219438
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic OMR: '76 KZ900 Restoration/Modification
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 11 Jun 2008 18:02 by Old Man Rock.
- Old Man Rock
11 Jun 2008 17:48 - 11 Jun 2008 18:03 #219440
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
last... If these don't go through I'll post later..
OMR
What a pain in the arse to get these images posted:blink:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 11 Jun 2008 18:03 by Old Man Rock.
- Old Man Rock
11 Jun 2008 17:50 - 15 Jun 2008 09:07 #219441
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 15 Jun 2008 09:07 by Old Man Rock.
- Old Man Rock
29 Jun 2008 12:59 #222862
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
29 Jun 2008 13:00 #222863
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 796
30 Jun 2008 09:57 #223062
by 531blackbanshee
Replied by 531blackbanshee on topic OMR: '76 KZ900 Restoration/Modification
this thing is coming together very nicely.good job.
- Old Man Rock
01 Jul 2008 18:45 #223386
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Just updating the counter & rear sprocket data...
As written previously, due to difficulties obtaining a 1/2, 18 tooth, 530 CC sprocket I re-grouped and went with the 630 configuration....
AmericanClassix.com
CC Sprocket:
OS15 - front sprocket 15-630 0.5 offset
Qty: 1 at $84.50
Z1 Enterprises.com (Thanks Jeff!)
Rear Sprocket & CC Washers/Spacers:
630 (JTR501 series) 37T Rear Sprocket
Quantity: 1 Product ID: TU24-9607 Price: $33.26
Front Sprocket Spacer Washer - 1.25mm
Quantity: 3 Product ID: SS-3 Price: $0.75
Here's how I measured, seems to have come out correctly.
KZ900 Stock Rim: 3.5" from center rim to inside sprocket.
ZX6RR Stock Rim: 4.25" from center rim to inside sprocket.
Subtract the differences = .75" = 19.05mm
subtract the offset 13.5mm = 5.55mm
subtract the 3 spacers at 1.25mm each = 1.8mm = .0709" =
< then 1/16"...
In measuring the sprockets to frame and tire I measure 1/2" spacing. I ordered a chain from Jeff at Z1 but won;t be here till next week. a 630 Chain - RK 102 link XW-ring
This will be the true and final confirmation to frame and tire and I'll post the results later.
Thanks Steell for turning me onto JT Sprockets... Mix and match the templates of different years, all is good!
Hope this may help others,
AmericanClassix.com
CC Sprocket:
Qty: 1 at $84.50
< then 1/16"...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mark1122
- Keep twisting it
- Thank you received: 109
03 Jul 2008 08:09 #223720
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic OMR: '76 KZ900 Restoration/Modification
Thezx7 reasets look very nice.
:woohoo: now u need to show us the other side.lol. what year are they? it looks like they are a direct bolt on.is that right?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
03 Jul 2008 11:34 - 03 Jul 2008 11:36 #223768
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
what year are they?
Unknown, got out of a bike junk yard for $40... Buffed them out, look great.
It looks like they are a direct bolt on is that right?
No, had to do some minor fabrication. Once I figured out where I wanted them on the frame, I welded some matching bolts onto my frame then attached (screwed) on the coupling nuts you see in the image.
The beauty of this is I can now adjust any offsets due to the frame not being linear.
Then mount the rearsets to the nuts, all better...
In the image they are painted but I have found these at Ace hardware in Chrome....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Jul 2008 11:36 by Old Man Rock.
- mark1122
- Keep twisting it
03 Jul 2008 18:31 - 03 Jul 2008 18:33 #223841
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
NICELY DONE OMR.NICELY DONE.
can i see the other side . can i ha , can i?:woohoo:
do u do your own welding and machining?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 03 Jul 2008 18:33 by mark1122.
- Old Man Rock
04 Jul 2008 06:48 #223907
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Glad you like!
"do u do your own welding and machining?"
Yes on all the welding and frame fabrication such as the rear shock mounts etc... Regarding the machining, all depends.
For the recent L.E.D. tail light mounts I did myself and I'm planning on a fabricating the rear hugger in buffed aluminum... It's a secret for the time being but it's going to be whacked if I can pull it off... For the headlight all depends on what light I end up with, still debating dual 5.25" or one huge 7"...
When it comes to cylinder boring, machining on the head such as the valve guides/seals, port & polish etc... then I'll leave that to the pros...
for some things are out of my league and I want it done right, no boo-boos!
As can be reviewed in the image, I still have to obtain a coupling nut between the shift lever and shift lever clamp on the output shaft.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mark1122
- Keep twisting it
04 Jul 2008 06:58 #223909
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Looks great.be carfull that your bike does not fall off those stands. dont ask me how i know that can happen.:silly:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
