- Thank you received: 225
OMR: '76 KZ900 Restoration/Modification
- Old Man Rock
27 May 2008 19:50 #216290
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
OMR: '76 KZ900 Restoration/Modification was created by Old Man Rock
Hey all,
Since I didn't really nowhere to place this posting in the forum, I figured this is a good as place as any.
As can be reviewed in the next two postings (only 1 image at a time :blink: ) I finally have started putting the old girl back together. Still have a lot of work but she is looking friggin beautiful!
Constructive criticism welcome....
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
27 May 2008 19:51 - 27 May 2008 19:52 #216291
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Replied by Old Man Rock on topic OMR: '76 KZ900 Restoration/Modification
Swing Arm Image set 2....
BTW... This is not chrome boys & girls but Buffed Aluminum... :woohoo:
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 27 May 2008 19:52 by Old Man Rock.
- Old Man Rock
27 May 2008 19:57 #216296
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kztee
- TeeRoy
27 May 2008 20:04 #216299
by kztee
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
Replied by kztee on topic OMR: '76 KZ900 Restoration/Modification
I recently got a gs1100 swingarm to put on my '77 1000. It needs a good cleaning and I would love to end up with it looking close to as nice as yours. Please explain what you did to get it to look that good
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- PLUMMEN
- Thank you received: 104
27 May 2008 20:48 #216309
by PLUMMEN
Replied by PLUMMEN on topic OMR: '76 KZ900 Restoration/Modification
lots of block sanding followed by lots of rubbing and buffingB)
- donthekawguy
- Thank you received: 8
27 May 2008 23:32 #216330
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic OMR: '76 KZ900 Restoration/Modification
Looking good! I'm starting to rethink my 2 year project and get it back together. :blink:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Old Man Rock
28 May 2008 05:06 #216340
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
kztee,
As Plummen wrote, patience and time is required. It took me roughly 2-3 days worth of work to strip the arm of factory black paint then sanding and buffing.
The trick is.... Apply your compound for 1 second only on your drill buff wheel while spinning. Don't apply too much at one time for it defeats what your trying to accomplish.
Then apply to your part for buffing. Don't work in just one spot, move it around as you would if sanding for example. The buffing wheel will go black in color as expected for your actually cutting the surface. Once you see that your not really cutting any longer, apply again your compound for 1 second and repeat.
For deep scratches sand down with 80 grit sand paper, then work your way up to 1000 grit to 2000 grit. For light surface scratches then buffing with Tripoli (medium cutting) should work just fine.
Then using a buff wheel on a drill (available at Lowes or Home Depot), buff with Tripoli to remove medium depth scratches and finish off with white compound (light cutting) for Bling!
Use the forum search key "Aluminum Buffing"... There's a lot of these guys that already have it figured out and have provided the answers for some truly beautiful work.
And by all means, post some images once finished and a write up of what you did, share the wealth of knowledge.
Good luck!
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 796
28 May 2008 09:31 #216379
by 531blackbanshee
Replied by 531blackbanshee on topic OMR: '76 KZ900 Restoration/Modification
oh yes good job omr.now post soem more of them pictures that you have been keeping from us
.btw how is your front end coming?
- henrymski
28 May 2008 10:07 #216382
by henrymski
Replied by henrymski on topic OMR: '76 KZ900 Restoration/Modification
I like your paint colors. I have been considering a similar combo with red and silver accent striping.
- tokyojrock
- Can't do the usual....
28 May 2008 10:16 #216383
by tokyojrock
Replied by tokyojrock on topic OMR: '76 KZ900 Restoration/Modification
Nice work on the shock mount! Looking good.
- saxjonz
- KawboyZ
- Thank you received: 76
28 May 2008 14:22 #216450
by saxjonz
79 LTD B3
Replied by saxjonz on topic OMR: '76 KZ900 Restoration/Modification
When I stop drooling I will get back to you on all of that. lol Love the paint and thanks for the 1 second tip. I just finished buffing my stuff and was holding the compound for at least a couple of seconds. Now I know. I started with the sand paper to remove all of the casting marks, etc. Lot of work that came out to be but I am glad because it was well worth it. I went black emory to the tripoli and then white but man those little scratches take a long time to get out! Don't hold back with the pics.
Pretty soon here I will have some time off and will do the same to my ride.:woohoo:
79 LTD B3
- Old Man Rock
28 May 2008 18:54 #216495
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Maybe this will help...
Caswell tutorial/guidance explains the compounds and buffing wheels to use.
members.cox.net/ruinsofstei/Buffbook.pdf
Remember, Use little (compound) and use often is the key;)
Now onto buffing my rims...
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
