1976 Kz 400d re-build 23 May 2008 19:20 #215440
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
  • Thank you received: 12
Ok guy's, sice gas is over $4.00 a gallon by me, i have decded to get the 400 up and running. Here's the history on her, she has 10,600 orig miles on the clock. I bought the bike in 2004 with just 1600 miles on her. hode it till i got my 77 650b, then it got parked cause i liked going faster. I started tearing her apart today, i took the tank, carbs, pipes, fenders, front and rear fender, coils, bars, gauges off. Tommorow im gonna attempt to pull the motor:huh: :blink: :S , i hope. My plan on her is to repaint the frame rattle can gloosy black, maby replace the seaping head gasket, the stock paint is in good shape with the exception of the clear coat peeling, i wanna keep the paint and just have it re cleared if at all possible, clean and polish the engine ( 000 steel whool and wd-40 do wonders), polish the front end and both wheels. What she need's, carb's cleaned out good, evhaust cleaned (possibly repaint hi temp black?), new dyna 3.0 ohm coil and new wires, new chain and sprokets, new points and condensors ( or replace with 440 electronic ignition), and re cover seat and new foam to. Here is a pic of her from a year or two ago. Il post more pics tommorow ASAP.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: by oldkaws4ever.
1976 Kz 400d re-build 23 May 2008 23:08 #215479
  • EasyRider1
  • EasyRider1's Avatar
  • Thank you received: 0
Cool! What kind of mpg do you get with the 400? I have a 440 and it's not a great as I'd like (40 something mpg).
1978 KZ650C
1976 Kz 400d re-build 24 May 2008 13:53 #215547
  • oldkaws4ever
last time i had her running in 04 it was getting around 50 mpg.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1976 Kz 400d re-build **with pics** 26 May 2008 14:30 #215992
  • oldkaws4ever
here are some pics of her stripped down. I like it like this maby a bobber or chopper in the works???
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1976 Kz 400d re-build **with pics** 26 May 2008 14:36 #215993
  • oldkaws4ever
another
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1976 Kz 400d re-build 28 May 2008 10:41 #216391
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
  • Thank you received: 7
My 400 gets like 55-58 mpg...
:blink:
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
1976 Kz 400d re-build 30 May 2008 16:44 #216843
  • oldkaws4ever
Ok, i did some more work to her the other night. Im deffinatly going to do a rigid bobber. I broke out the cutting wheel and started cutting off all the useless junk, seat latch rear fender support to clear the rear tire. I bought some square tubing to make the struts out of. Im also cutting off the passenger fotpeg supports cause she's gonna be a solo ride. I post more pics when i get a new battery for my camera.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1976 Kz 400d re-build 08 Jun 2008 19:50 #218848
  • EasyRider1
Any update on this 400? I'm interested to see how this bike is coming along.
1978 KZ650C
1976 Kz 400d re-build 18 Jun 2008 23:25 #220835
  • oldkaws4ever
Ok Ok sorry for the long wait. I lost my damn camera, it was in the bottom of my tool box, go figure huh? I have done tons of work to it, i painted the frame, struts, tripple trees, forks, headlight ears, fork guides and pretty much everything else that was chromed originoly glossy black. Here are a few pics to hold you guys over. Hopefully ill get her assembled and running within a couple weeks.
Heres the frame
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1976 Kz 400d re-build 18 Jun 2008 23:27 #220836
  • oldkaws4ever
Fork legs
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1976 Kz 400d re-build 18 Jun 2008 23:31 #220838
  • oldkaws4ever
motor mounts, brakets etc....
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1976 Kz 400d re-build 18 Jun 2008 23:36 #220841
  • oldkaws4ever
swingarm, struts and tripple trees
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
