Building a GPZ1150 from a CSR1000
  • otakar
  • otakar's Avatar Topic Author
Re: Building a GPZ1100 from a CSR1000
19 Jul 2008 12:36
#227102
A complete shot of everything mounted.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
19 Jul 2008 12:45 - 19 Jul 2008 12:51
#227104
Now I must go to her and pull the carbs off and re-jet them. She is running a bit lean both at high and low throtle settings. I checked the gas milage over the last week and I am getting 45MPG. This has been checked over 5 days and was confirmed and re-confirmed with may-be a .2 MPG difference between the days. I will continue with more modiffications next week. I will be installing a new front wheel with more modern disks. Installing new front fork seals. I have already installed new side marker lights (You know- the rflectors which are mounted on the front down tubes of the frame)yes I did say lights not reflectors. Also new HID light, the new K&S left handel bar control. Cell phone JAMMER (yes you are reading right)Jammer. and much more. This winter I will be installing the new engine top end and more.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 Jul 2008 12:51 by otakar.
  • kzwolfsr
  • kzwolfsr's Avatar
22 Jul 2008 06:02
#227602
Thanks for the pics. Do you slide the tail onto the rear rivetted on clip then screw it on to the jb weld post?
Original man of the Caribbean
  • otakar
22 Jul 2008 09:00
#227634
that is correct. There is a undercut lip on the tail which slips over the rear bracket.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
24 Jul 2008 05:54
#228018
Well- It's now been two weeks that I have been riding the beast and it is a smooth and pleasant ride. The problem arises at very low speeds IE idle and also at wide open. The bike is a bit rough at idle when the engine is hot and also has no power when I go over 6000 revs. I think that I am too lean at both ends. I left the stock idle jet and went three sizes larger on the big jets but I don't think that is enough. When I open the throttle to full in third fourth or fifth gear the bike just will not pull. When it gets to about 7000 which is about as high as it will go, it will pull a bit more if I actually bring the throttle back about a third. This is what is telling me that it is too lean at the top end. I would have thought that three sizes would be enough to compensate for the pod filters and the Kerker. I guess not. Any thoughts from you guys? I have never used CV carbs before and this is my first try with them. Any help would be appreciated.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
27 Jul 2008 19:37
#228604
Otakar,
Nicely done. Got pics of the whole bike? Left side and right side? Looks good in the close-ups; and nice work on the cold-welds...very nicely done.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • kpier998
  • kpier998's Avatar
27 Jul 2008 20:03
#228610
I had that exact symptom on my CB750 and went to leaner jets last summer to get it to pull at the higher throttle openings. My plugs were also black and when I used a lot of throttle, it was puffing a pretty good bit of black smoke. That might be something to look at. Another difference, I was getting really bad gas mileage.
In fact, I reduced both the primary and mains. I don't remember the primary size, but I decreased from 115s to 105 main jets in my particular case.
  • otakar
28 Jul 2008 05:29
#228648
On Saturday I did some more work on the bike. One of the things I did was totally disassemble, and rebuild the front forks. Boy what a difference. I will post a couple pictures later on this evening. I also did work on the carbs. I definitely noticed a big difference this morning. Where before I could not get her over 7000 I can now get to almost 9000, and she pulls a lot harder. I went a lot bigger on the jet size and think I will have to go even bigger. I will also post these #s this evening.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kzr750r1
  • kzr750r1's Avatar
29 Jul 2008 14:19
#228965
Did you buy the new shocks... Sorry, I flipped through this post pretty quick.
The company I beleive makes these is YSS. They are made in Thailand. The price is almost a third of other radial valved shocks out there.
www.yssusa.com
Looking at the G-Series.
I'm considering these as well so really interested in any feedback.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
  • otakar
29 Jul 2008 17:01
#228992
No I did not buy the ones in the picture, those were much too short. The shocks that I did put on thare are new hoever, they are aftermarket for a Honda Goldwing. They are 1.5 inches longer than stock. Due to the two inch longer Suzuki swing arm that is on the bike. If however I can find shocks of that tipe at the link you sent me, that are long enough, I will buy them.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kzwolfsr
  • kzwolfsr's Avatar
29 Jul 2008 17:21
#228997
Thanks for the descriptions. I have the tail, now I just have to find the seat. Is that the gpz seat or another one you found? How do you find this stuff?
  • otakar
29 Jul 2008 18:03
#229009
That is a GPZ seat bought on eBay. Than I just cut and modified the pan with a Dremmel tool.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
