Building a GPZ1150 from a CSR1000
- otakar
Re: Building a GPZ1100 from a CSR1000
19 Jul 2008 11:40
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 11:42
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 11:43
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 11:45
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 11:47
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 11:53
By the way, I did make two of these lights for anyone who wants to mount one on their oryginal tail light bracket. I had to buy two of the truck lights so I built two KZ lights The light is complete as you see it here on the right, for $100.00 There are plugs also installed on the wires and the maits to them for the bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 11:57
Now a bit about the rear turn signals. decided to replace the standard signals with a set of front signals which are a bit shorter than the stock rear lights and have sockets for dual elemant bulbs installed. After that it is a simple task of just spliceing into the tail light marker wire for the marker side lights.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 12:06
The Bulbs inside all side signal lights are also LEDs. Here is a shot of the new wireing for the back turn signals. You can compair it with the picture previously posted in this thread.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 12:08
Here is a few pictures of the mounting of a non standard Aluminum Chain guard from a "Concourse" to the GS1100 swing arm. The front mount first.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 12:10
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 12:12
A clear shot of the left side repositioned rear-set foot peg. The front mount oryginal position is clearly visible.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jul 2008 12:17
More LED marker lights. This one will replace the need to opperate the main head light, once I replace the oryginal left handel bar control switch with a new K&S control. This Mod will be covered at a later date but the light is installed already. The reason for this is because the LED light only consumes 1 Wat of power while the light on low-beam consumes 60 wats.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
