zeroclearance
posted on 7-10-2005 at 13:39 |
pod help
ok, so i finally decided to get around to installing my pods and i looked today and i was wondering what all i have to take off and what i should do
with the ventilation hose thats attatched. I dont want to be ripping things off when i really dont have to so i figured asking more knowledgeable
people first would save me some time. Thanks in advance. oh yeah its a kz440AE
82 kz 440 ltd with drag bars, pods and heat wrapped free flowing exhaust
DasTeufel
Newbie
posted on 7-10-2005 at 16:02 |
Hi, I recently installed pods on my 82 KZ550 LTD. If you are referring to the vacuum switch, you can remove it, make sure that you plug the ports of
any lines you take off. I removed the vacuum covers on the valve cover, and very carefully tapped them and installed a pipe plug in each cover. I will
say I got real lucky and did not have to jet my bike, performance is great. You may have to rejet though. As for the crankcase vent, just install a
filter or a tube and filter.
