Author: Subject: Magnetic Oil Drain Plug
capnrob
Junior Member
Mood: KZ 400 Happy
[*] posted on 25-10-2004 at 06:50
Does anyone use magnetic oil drain plugs for their KZs. I use to have a BMW and it had one on it. It seemed to pick up the small metal shavings from the motor and didn't allow them to be recirculated by the pump.... Does the oil filter do a good enough job of filtering this or should these plugs be added for addional protection
Robert
kawtoy
[*] posted on 25-10-2004 at 07:35
I use one. For a few bucks it seems like cheap insurance to me. It does pick up very tiny bits of metal. I am sure the filter would pick them up also but better safe than sorry.
1980 KZ1000 Streetfighter (94 FZR front and rear ends, Yosh 10.5-1 comp pistons, stage 3 jet kit, Kerker 4-1 with Yosh muffler, accel coils, PMFR clutch release kit, struts, all work and paint done by me..410 cams ready to drop in)
1982 Honda Express
1981 XS650
1972 Honda CB350
1974 Honda CB350
Jeff.Saunders
Mood: ride ride ride
[*] posted on 25-10-2004 at 08:48
I'm with Kawtoy on this - plus as it tends to attract any iron / steel particles, when you do drain the oil, it allows you to easily see if the engine has some problems.
The oil filter may trap the particles, but unless you cut open the filter, you may not see them.
jeff@z1enterprises.com
http://www.z1enterprises.com
2 x 73 Z1's (one turbo'd), 1 x 74, 1 x 76 KZ900, some Honda's (CB750's and CB550), a Suzuki GS750
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member Jeff.Saunders's Aim This User Has MSN Messenger
KZ_Kat
Mood: Hauling Ass!
[*] posted on 25-10-2004 at 10:39
Can you even get one to fit a Kaw? I need a new one anyway, prob go up a size since my threads are messed up.
Size and p/n please?
:D
1979 KZ650sr- Black Lacquer, Piped, Jetted, K&N Pod Filters
Life should NOT be a journey to the grave
with the intention of arriving safely in an attractive and well preserved
body, but rather to skid in sideways - Chardonnay in one hand - strawberries
in the other - body thoroughly used up, totally worn out, and screaming -
WOO HOO! What a Ride!
PuGz
Mood: Vroom Vroom!
[*] posted on 25-10-2004 at 14:39
you should stock these jeff. :-)
1979 KZ650 (Super Strech)
1976 KZ900 (Project Bike)
1980 KZ750 Twin (becase I can)
[img]http://services.nexodyne.com/email/icon/pW114WvB.MwvidFo/cFhWsQM%3D/R01haWw%3D/0/image.png[/img] PuGzWorld
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
Jeff.Saunders
[*] posted on 25-10-2004 at 14:58
We stock them for the KZ900's & 1000's - I'll have to see if I can find them for the other KZ's.
philcsand
Mood: Winging it
[*] posted on 25-10-2004 at 15:41
How much of the engine is actually ferrus metals?
Rides:
1980 KZ750 H1 LTD "Kruzer"
1984 GL1200 Interstate "Lay-Z"
<<<Kill a biker, go to jail.>>>
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member philcsand's Aim philcsand's ICQ status philcsand's Yahoo
Jeff.Saunders
[*] posted on 25-10-2004 at 16:02
Phil - good question... tough one to answer easily as it varies significantly with each model.
The Z1/KZ900/KZ1000 engines have a couple of areas where the engine can create iron metal particles.
The cam bearings are one (but most of the other KZ family do not use cam bearings, the cam journals are machined directly into the head).
The front cam chain guide is another area where the guide wears or breaks and those chunks often appear in the oil pan.
Other than these two areas, there are not a lot of places where ferrus metal particles can be generated unless there is a very serious problem.
For those familiar with the other KZ models, maybe someone can provide some insigth to where there is wear.
Ron G
Mood: Frisky
[*] posted on 25-10-2004 at 16:35
The transmission is a major source of ferris debris in the engine oil.
My trusty magnet informed me that the following engine parts also contain ferris/magnetic material:
Clutch Disks
Cylinder Sleeves
Piston Rings
Wrist Pins
Crankshaft
Crankshaft Bearings
Camshafts
Camshaft Bearings
Cam Buckets
Valve Shims
Valve Guides
The main reason I have a magnetic drain plug is because the transmission is lubricated by the engine oil.
Ron
View User's Profile E-Mail User View All Posts By User U2U Member This User Has MSN Messenger
Biquetoast
Mood: The Kaw mood ;)
[*] posted on 26-10-2004 at 06:08
The first thing I thought of was the tranny. I'd love to have these for my 3 bikes... not sure of the general demand for such an item, but I'm sold...
(1.) '75/'76 KZ400D - Coming back from the grave
(2.) '78 KZ750B3 Twin - Daily Rider
(3.) '78 KZ750B3 Twin - Pretty much just sits there...
See pictures of the twins!
Update 20050905 - Something wrong inside the 400 engine. Time for the big teardown...
ibsen22000
KZ King
[*] posted on 26-10-2004 at 07:08
[quote][i]Originally posted by Jeff.Saunders[/i]
We stock them for the KZ900's & 1000's - I'll have to see if I can find them for the other KZ's. [/quote]
Just to make it easier for you Jeff. Almoast all Kawasakis from 1976 and up to 1995 used the same 12X15 oil drain plug. :cool:
View User's Profile Visit User's Homepage View All Posts By User U2U Member
SandRacer
Mood: Ready to fab!
[*] posted on 26-10-2004 at 07:29
Wow! I just looked up the plug for my '88 Police on my new disk, from Steve @ Zedder, and then checked what else shared the part. The list was staggering. Everything from ATV's, KZ's, ZN, Ninjas to Mules.
Better stock up on plugs Jeff. In case I forget, remind me on my next order.:D
Fat Kaw, Part 1
Fat Kaw, Part 2
Fat Kaw, Part 3
1988 KZ1000P the Fat Kaw
2001 V-Star Custom (For Sale)
1972 F8 Enduro (Parting out)
1969 Bushmaster (Parting out)
1980 KZ750 LTD (Parts Bike)
Every day is a holiday and every meal is a banquet!
KLACKO
Mood: expectant
[*] posted on 26-10-2004 at 07:32
[quote][i]Originally posted by PuGz[/i]
you should stock these jeff. :-) [/quote]
You should be ashamed for even thinking Jeff wouldn't have these. Tsk-tsk...:D
1981 KZ 440 LTD (belt)
1983 KZ750L Sport (project)
1978 GL1000 (long-term project)
Welcome to the KZr Institute for the Mechanically Insane
PuGz
Mood: Vroom Vroom!
[*] posted on 26-10-2004 at 08:45
Notice that I ride a kz650 :P
Jeff.Saunders
[*] posted on 26-10-2004 at 11:34
There are ddifferences between the KZ650 and KZ900 drain plugs. Kawasaki lists two different part numbers / specs.
92001-1183 listed as 19mm x 15 Z1 KZ900 KZ1000 (thru 1980) KZ1300 KZ400 (some)
92066-1174 listed as 12mm x15 KZ1000 (J motor and later) KZ400 (some) KZ440 KZ550 KZ650 KZ700 KZ750 and many more non-KZ models
I will order some of the KZ650 style plugs (to be honest, I don't know why I overlooked them before).
[PHP: 78.8% - SQL: 21.2%]
